Fit multiple systems from FOR loop
I am working on the problem previously described in viewtopic.php?f=3&t=282. I am now implementing an automated fitting of EPR spectra based on a set of subspectra automatically generated by a FOR loop, based on a theoretical model.
My main function is:
clear all; close all; format long;
[B,spc,params] = eprload('AKB1004A_4.3K_X_powder_01.DTA');
Si = 3/2; % The spin of the individual ions
Jav=-10.9; % Isotropic exchange in cm-1 according to the -2JSiSj formalism
r=0.05; % Radial distortion coefficient
gz=1.971; %g|| common for all ions
gxy=1.971; %gperpendicular common for all ions
iter=3; %Number of subspectra
wG=0; %Gaussian linewidth
wL=2; %Lorentzian linewidth
Gx = 0; Gy = 0; Gz = 0.2; % Antisymmetric exchange pseudovector components
SysA.Si = Si;
SysA.Jav = Jav;
SysA.r = r;
SysA.gz = gz;
SysA.gxy = gxy;
SysA.iter = iter;
SysA.wG = wG;
SysA.wL = wL;
SysA.Gx = Gx;
SysA.Gy = Gy;
SysA.Gz = Gz;
VaryA.Jav = 0;
VaryA.r = SysA.r;
VaryA.Gz = Gz;
VaryA.gz = 0.0;
VaryA.gxy = 0.0;
VaryA.wG = 0;
VaryA.wL = 0;
Exp.Temperature = 4.3; Exp.mwFreq=params.MWFQ/1e9; Exp.CenterSweep=[params.A1CT*1e3 params.A1SW*1e3]; Exp.nPoints=params.XPTS;
FitOpt.Method = 'simplex fcn'; % simplex algorithm, data as is
FitOpt.Scaling = 'lsq0';
esfit('constrainJg_equilateral_dynamic_EPR_fit',spc,SysA,VaryA,Exp,[],FitOpt);
My custom function is:
function y = constrainJg_equilateral_dynamic_EPR_fit(SysA,Exp,Opt)
cm=100*clight/1e6; % Conversion constant from cm-1 to MHz
%Define the theta angles (y-O-Mj) for each metal center
theta1=0;
theta2=-2*pi/3;
theta3=2*pi/3;
GG = [0 SysA.Gz -SysA.Gy; -SysA.Gz 0 SysA.Gx; SysA.Gy -SysA.Gx 0];
%Variation of phi angles of the central oxide
for i=1:SysA.iter
phi(i)=((i-1)/SysA.iter)*(2*pi/3);
%Construct multiplicative factors for each spin pair and for each iteration
a12(i)=SysA.r*(cos(phi(i)-theta1)+cos(phi(i)-theta2));
a13(i)=SysA.r*(cos(phi(i)-theta1)+cos(phi(i)-theta3));
a23(i)=SysA.r*(cos(phi(i)-theta2)+cos(phi(i)-theta3));
% Individual isotropic exchange constants
J12(i)=SysA.Jav*(1+a12(i));
J13(i)=SysA.Jav*(1+a13(i));
J23(i)=SysA.Jav*(1+a23(i));
%The individual systems
Sys(i).S=[SysA.Si SysA.Si SysA.Si];
Sys(i).g=[SysA.gxy SysA.gz; SysA.gxy SysA.gz; SysA.gxy SysA.gz];
Sys(i).gFrame = [90 90 -45; 30 -90 235; -30 90 -45]*pi/180;
% Sys(i).weight = 1/SysA.iter;
Sys(i).ee = [-2*J12(i)*eye(3) - 2*GG; -2*J13(i)*eye(3) + 2*GG; -2*J23(i)*eye(3) - 2*GG]*cm;
Sys(i).lwpp=[SysA.wG SysA.wL];
[B,calc] = pepper(Sys(i),Exp); % Calculate subspectrum No (i)
calcspc(i,:) = calc; % Put the result in a row of an array
y = sum(calcspc); % Sum each subspectrum in the array
figure(1)
plot(B,calcspc)
hold on
plot(B,y)
legend('show')
hold off
figure(2)
plot(phi,J12,phi,J13,phi,J23)
legend('show')
return
The problem is that each subspectrum seems to be almost identical, despite the variations of the Jij values, which should greatly influence the gperp components. I suspect that there is a problem in the invocation of pepper in:
I have double-checked with a model with two manually created subsystems and it works as predicted. Does anyone see an error that eludes me?
Thanks!
Re: Fit multiple systems from FOR loop
And the spectrum
AKB1004A_4.3K_X_powder_01.zip
(4.94 KiB) Downloaded 186 times
I suggest You have to check the dimensions of the pepper output and Your array calcspc as well as the result or the sum(calcspc). I'm afraid that pepper returns column vector instead row. In this case calcspc(i,:) = calc'; should solve the problem.
Thanks katarkon.
In my installation (Matlab R2015a on Linux), pepper returns B and calc as row vectors. So calcspc contains the spectra along the rows.
What microwave frequency are you running this at? Based on your Jav value, this appears to be in the strong-exchange regime, where the spectra will not be affected by small changes in Jav (the factors a12 etc are much smaller than 1).
I am working at 9.31 GHz.
After some experimentation, I discovered that it was an issue of parameters: I needed to increase Gz (to ~0.8 cm-1) so that the Jij differences became visible in gperp. Then, with r ~ 0.2, I started seeing the effect.
Indeed, as you say the spectra are insensitive to Jav, but their gperp is sensitive to ΔJij due to the antisymmetric exchange.
