Hyperfinesplitting drawing program
I would like to draw diefferent splitting schemes like in the picture ( ).
Does anyone know a program to create them?
Best regards
moreutz
Best regards
moreutz
Re: Hyperfinesplitting drawing program
You may try this script. Just change the spin system as You want.
clear, clf
Sys.g = 2;
Sys.Nucs = '14N,1H,1H';
Sys.lw = [0,0.02];
Sys.A = [10; 5; 2]; % MHz
Sys.n=[2 1 4];
Exp.Range=[343 347];
Exp.mwFreq = 9.65;
Exp.nPoints=4096;
Exp1=Exp;
Exp1.Harmonic=0;
Opt.Method='perturb1';
nspin=numel(Sys.A);
for i=0:nspin
if i>0
Sys1=nucspinkeep(Sys,1:i);
else
Sys1=nucspinrmv(Sys,1:nspin);
Sys1=rmfield(Sys1,'lw');
yy=garlic(Sys1,Exp1,Opt);
yy=yy/max(yy);
y(:,i+1)=yy;
[x,yy]=garlic(Sys,Exp,Opt);
yy=yy/max(yy);
y(:,nspin+2)=yy;
stackplot(x,y,1,1.1);
This script draws splitting scheme as on the picture. Just define required spin system and correct field range. Equivalent nuclei and isotope mixtores does not supported yet.
clear, clf
% Parameters
% Spin system
Sys.g=gfree;
Sys.Nucs='14N,14N,1H';
Sys.A=[10 12 5];
Sys.lwpp = [0,0.02]; % Lorentzian lines
Exp.CenterSweep = [339.4, 2];
Exp.nPoints = 4096;
Exp.mwFreq=1e-3*mt2mhz(Exp.CenterSweep(1),mean(Sys.g));
% Simulations
[xa,ya] = garlic(Sys,Exp);
% Diagram calculation
if isfield(Exp,'Range'), dx=1/mt2mhz(max(Exp.Range)-min(Exp.Range),mean(Sys.g));end
if isfield(Exp,'CenterSweep'), dx=1/mt2mhz(Exp.CenterSweep(2),mean(Sys.g));end
nNucGroups=0;
if ~isempty(Sys.Nucs)
I = nucspin(Sys.Nucs);
nNucGroups = max(size(Sys.A));
dy=1/(1+3*nNucGroups);
if numel(I)~=nNucGroups, error('Sys.A and Sys.Nucs are not consistent.'); end
set(gcf,'Color','w');
axes('Position', [0 0 1 1]);
plot(xa,ya,'k');
axis off;
axis([min(xa) max(xa) min(ya)*(1+2*nNucGroups) max(ya)]);
y=0;
x=[0.5];
annotation ('line',[x x],[y dy]); %first line
y=y+dy;
for i=1:nNucGroups
mI = -I(i):I(i);
x2=[];
for j=1:numel(x)
x1=x(j)+dx*Sys.A(i)*mI;
for k=1:numel(x1)
annotation ('line',[x(j) x1(k)],[y y+dy],'LineStyle',':'); %splitting line
annotation ('line',[x1(k) x1(k)],[y+dy y+2*dy]); %next line
x2=[x2 x1];
x=x2;
y=y+2*dy;
The support for equivalent nuclei is added.
clear, clf
% Parameters
% Spin system
Sys.g=gfree;
Sys.Nucs='14N,1H';
Sys.A=[10 0.6];
Sys.n=[2 12];
Exp.nPoints = 4096;
% Simulations
nNucGroups=0;
if isfield(Sys,'n')&&max(Sys.n)>1 %equiv nucs
for i=1:numel(Sys.n)
if Sys.n(i)>1
[I1,~]=equivcouple(I(i),Sys.n(i));
I(i)=I1(1);
plot(xa,ya,'k');
axis off;
axis([min(xa) max(xa) min(ya)*(2.5+2*nNucGroups) max(ya)]);
y=0;
x=[0.5];
y=y+dy;
for i=1:nNucGroups
mI = -I(i):I(i);
x2=[];
for j=1:numel(x)
for k=1:numel(x1)
x2=[x2 x1];
x=x2;
y=y+2*dy;
Thank you very much!
Unfortunately I have an natural isoptope mixture (Sys.Nucs = 'N,H')..
- EasySpin Guru
For both N and H you generally don't need to worry about natural isotope mixtures, as their isotope abundances <<1%.moreutz wrote:Thank you very much!
This is my input:
So I get this diagram:
Why isn't it correct?
Sys.A = mt2mhz([1.49 1.49]);
Sys.g = 2.005;
Sys.lwpp = [0 0.12];
Sys.Nucs = '14N,1H';
Sys.n= [1 1];
Exp.mwFreq = 9.44;
Exp.nPoints = 4096;
Exp.Range = [331 342]
The diagram starts drawing from the center of the figure. The spectrum have to be centered too. It may be forced by either
Sorry, this is indeed unclear moment.
or Exp.mwFreq=1e-3*mt2mhz(mean(Exp.Range),mean(Sys.g));
depending how You prefer define the field range.Sorry, this is indeed unclear moment.
Perfect, thanks a lot!
