I have fitted three different radicals to an experimental spectrum. It fits quite good, but by exporting the spectra the intenisites between the experimental spectrum and the fitted spectrum vary widely. The simulated spectrum has an intensity range from -1 to 1.
How can I generate a spectrum with the same intensity range?
Best regards
moreutz
Different intensities between experimental spectrum and simu
- EasySpin Guru
Re: Different intensities between experimental spectrum and
You can use the
rescale
function to scale your simulation to best match your experimental spectrum.
