"Operands" error when using Exp.Ordering
I am trying to use the Exp.Ordering parameter in ES 5.2.9 to fit a spectrum of two centers with dipolar and hyperfine interactions. The code works well until I include Exp.Ordering, at which time I get the error:
Operands to the || and && operators must be convertible to logical scalar values.
Error in pepper (line 450)
Error in pepper (line 159)
Error in constraingdip_exact (line 21)
[x,y] = pepper(fullSys,Exp,Opt);
Error in esfit>assess (line 831)
Error in esfit_simplex (line 77)
Error in esfit>runFitting (line 677)
My code is:
clear all;
close all;
cm=100*clight/1e6;
[B,spc,params] = eprload('PhCOO1.spc');
ACuxy=0; ACuz=270; %Aperp and Apar for Cu in MHz
r = 4.5; % Distance in Angstrom
eta = 0*pi/180; % eta angle
xi = 0*pi/180; % xi angle
Sys1.S = [1/2 1/2];
Sys1.g=[1.6 2.3; 1.6 2.3];
Sys1.Nucs = '63Cu,63Cu';
Sys1.A = [ACuxy ACuz 0 0; 0 0 ACuxy ACuz];
Sys1.gStrain = [0.02 0; 0.02 0];
Sys1.r = r;
Sys1.eta = eta;
Sys1.xi = xi;
Sys1.lwpp=[0 4];
Exp.Temperature = 4.6; Exp.mwFreq=params.MF; Exp.CenterSweep=[params.HCF/10 params.HSW/10]; Exp.nPoints=params.RES;
Exp.Ordering = +1;
Vary1.g = [0.0 0.1];
Vary1.gStrain = [0.01 0.00]; % Axial system
Vary1.A = [0 50];
Vary1.r = 0.1;
Vary1.eta = 0*pi/180;
Vary1.xi = 0*pi/180;
Vary1.lwpp = [0 0];
FitOpt.Scaling = 'lsq1';
esfit('constrain',spc,Sys1,Vary1,Exp,[],FitOpt);
And my function is:
function [x,y] = constrain(Sys1,Exp,Opt)
gx = Sys1.g(1,1); gy = Sys1.g(1,1); gz = Sys1.g(1,2);
Jxx = gx^2*(1-3*sin(Sys1.eta)^2*sin(Sys1.xi)^2);
Jyy = gy^2*(1-3*cos(Sys1.eta)^2*sin(Sys1.xi)^2);
Jzz = gz^2*(1-3*cos(Sys1.xi)^2);
Jxy = -3*gx*gy*sin(Sys1.xi)^2*sin(Sys1.eta)*cos(Sys1.eta);
Jxz = -3*gx*gz*sin(Sys1.xi)*cos(Sys1.xi)*sin(Sys1.eta);
Jyz = -3*gy*gz*sin(Sys1.xi)*cos(Sys1.xi)*cos(Sys1.eta);
fullSys = Sys1;
fullSys.g = [Sys1.g];
fullSys.gStrain = [Sys1.gStrain(1,1) Sys1.gStrain(1,2); Sys1.gStrain(1,1) Sys1.gStrain(1,2)];
fullSys.A = [Sys1.A];
fulSys.Nucs = '63Cu,63Cu';
fullSys.ee = 12993*Sys1.r^-3*[Jxx Jxy Jxz; Jxy Jyy Jyz; Jxz Jyz Jzz];
return
Thanks for the help!
Re: "Operands" error when using Exp.Ordering
And here is the spectrum files
PhCOO1.zip
(9.27 KiB) Downloaded 207 times
This is a bug, thanks for reporting. We will fix it.
Even after fixing, however, this won't work, since EasySpin currently does not support strains and ordering at the same time.
Thanks Stefan!
No problem, I will try it out without the strains when the bug is fixed.
Thanasis
Fixed in 5.2.10.
