Bug in esfit function (EasySpin 5.2.0)
The function esfit() throws an error in interactive mode.
Error using set
Value must be numeric
Error in C:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Re: Bug in esfit function (EasySpin 5.2.0)
(1) Which Matlab version are you using?
(2) Please post your input to esfit.
Matlab version is R2012b. Error throws by any script from examples. For instance, basicfit.m output:
Error using set
Error in E:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Error in basicfit (line 37)
esfit('pepper',spc,Sys0,Vary,Exp,SimOpt,FitOpt);
Fixed in 5.2.1. Thanks for reporting!
Best spectrum (green) is drawn spontaneously now. It seems to be appeared only when the best parameter set changes. So, if better set will not be found during the fitting the spectrum never be drawn. Should it be so?
Behavior is now improved in 5.2.2
Thanks. It works habitually now.
