curry / variation of field and temperature
radovanh
Post by radovanh »
Dear developers
I would like to calculate magnetic properties for given pairs of T and B, so I defined
Exp.Temperature and Exp.Field as follows
Exp.Temperature =[2 5 10 ...300 2 2 2 2 2]
Exp.Field = [1 1 1 ....1 0 1 3 5 7]
because I would like to have data set for
T B M
2 1 value
5 1 value
10 1 value
300 1 value
2 0 value
2 1 value
2 3 value
2 5 value
2 7 value
which I could eventually used also for esfit.
However, curry calculates magnetization for all combination of Temperature and Field!
So in the end, I have matrix of Magnetization for
T 2 5 10 ...300 2 2 2 2 2
B
1
1
1
1
1
0
1
3
5
7
Then, of course, esfit does not work.
Is it somehow possible to tell easyspin to calculate magnetic moment only for given combination of T and B, that means for
Exp.Temperature[1] and Exp.Field[1], then for [Exp.Temperature[2] and Exp.Field[2]... and last Exp.Temperature[n] and Exp.Field[n]
Thank you very much for any help
Radovan
Re: curry / variation of field and temperature
Field = [1 1 2 2 2];
Temp = [1 2 3 4 5];
for k = 1:numel(Temp)
  Exp.Temperature  = Temp(k);
  Exp.Field = Field(k);
  muz(k) = curry(Sys,Exp);
radovanh
Post by radovanh »
Thank you for help.
So this is the way to do calculation for one set of parameter.
But evidently, it is not suitable for ESFIT, maybe in some of next releases.
Once more thank for help
Radovan
joscha_nehrkorn
Post by joscha_nehrkorn »
You can define a custom function for fitting. See:
http://easyspin.org/easyspin/documentat ... omfunction
