Output separate transitions for specific crystal orientation
Murad
Post by Murad »
I am using pepper to generate the EPR spectrum of two coupled spins. I would like to find out which Zeeman levels are active in each transitions at a given crystal orientation. However, using
Opt.Output='separate';
at a specific crystal orientation does not work because EasySpin is looking to 'separate' the spectra of individual crystal orientations rather than separate individual transitions as would be the case if
Exp.CrystalOrientation=[];
. Is it possible to get both of these pieces of information in one go? Currently I am calculating the full spectrum, with
[x,y,trans]=pepper(Sys,Exp,Opt);
and then examining trans and using Opt.Transitions to generate the individual transitions. Is there a faster way around this?
Thanks,
Murad
Re: Output separate transitions for specific crystal orienta
For a crystal spectrum, you can use resfields(). This will give you a list of resonance fields and intensities.
Murad
Post by Murad »
Thank you very much - that was exactly what I was looking for!
