Dear Professor,
I use the easyspin and I have a question:
For the extraction of the theoretical cw EPR spectrum, easyspin finds the looping transitions for each of the signals.
I am interested to find the exact orientation at which a looping transition happens, that results in the respective signal.
I try using the Exp.CrystalOrientation for different angles, in order to find the exact orientation for a looping transition. Is there any more easy way or an other option to find it?
Thank you in advance
Dr. Georgia Zahariou
looping transitions
Re: looping transitions
Unfortunately, there is no general simple way of locating looping transitions with their bifurcation/coalescence points. Varying the crystal orientation is indeed the best way to do this.
Thank you very much for the reply!
Georgia
Georgia
