Dear Authors,
Is there a way to read in a set of EPR spectra measured as a function of MW power in order to calculate the saturation curve and fit the T1 and T2?
Thank you!
All best,
Dominik
Saturation curve simulation (CW T1, T2 measurement)
Re: Saturation curve simulation (CW T1, T2 measurement)
Use the
Otherwise, use a for loop to read in all the files. Assuming you named them systematically, you could use something like
eprload
function. If your data comes as a single file, one call is enough.Otherwise, use a for loop to read in all the files. Assuming you named them systematically, you could use something like
P_dB = [0 3 9 12 15 18 21 24 27 30 33 36 39 42]; % mw power in dB
for iP = 1:numel(P_dB)
filename = sprintf('mydata_%d_dB.DTA',P_dB(iP)); % make filename
[x,y_] = eprload(filename); % read in 1D data
spc(:,iP) = y_(:); % store data as column in a matrix
