Dear all,
I am having difficulties in loading only few EPR spectra. Can anybody help me out with this error ?
Invalid field name: 'à'.
Error in eprload>readPARfile (line 1190)
Error in eprload>eprload_BrukerESP (line 510)
Error in eprload (line 169)
Error in splitfile (line 8)
[B,spec]= eprload('150820_SC_11_AC044+10eqTEA_293K_13dB');% Replace the filename with your filename
loading EPR spectra
loading EPR spectra
- EasySpin Guru
Re: loading EPR spectra
It would be helpful if you could provide us with an example file that is providing this error.
please find the epr data file attached herewith.
- epr_data.zip
- (40.42 KiB) Downloaded 631 times
- EasySpin Guru
For a quick fix, I'd suggest slightly modifying your .par file, namely removing the last several lines of it(the ones containing the non-standard characters) and re-saving it. With those lines removed eprload works just fine.
However that particular bug will be fixed in future versions.
Thanks, it worked after editing
This should be fixed in the new release 5.0.9.
