eprload with specman files
In ES 5.0.x the ability of eprload to import specman files into MATLAB was greatly extended. If you're running into problems, e.g. what was working before isn't now, it wasn't doing what you wanted before and it still doesn't.
Please upload an example file or two(include both the .d01 and .exp) into this thread so I can work out the bugs.
iliak
Re: eprload with specman files
Post by iliak »
I tried to use eprload from the EasySpin 5.0.21 version and it failed with several 2D files recorded recently with SpecMan. Same file is successfully opened with eprload from ver 4.5.5. An example file is attached. Thanks for your help.
Ilia
example.zip
expected outcome is a 2D matrix with dimensions of 5000x8
(221.05 KiB) Downloaded 1016 times
This issue should be fixed in 5.0.22. Let us know if you still get errors.
iliak
Post by iliak »
Works not (5.0.22)!
Please let us know what is not working (e.g. post any error messages that are issued).
iliak
Post by iliak »
What a particularly nasty typo, I meant "works now!".
My sincere apologies
Thanks for the clarification!
