Ramsey Sequence code example
jcammera
Post by jcammera »
Could you recommend a parameter set for performing a Ramsey 2 pulse sequence for a spin 1 system with a 14N nucleus?
I know that the Ramsey contains two pi/2 pulses separated by and interstitial delay of between them.
How do you specify the delay between the 2 pulses?
Re: Ramsey Sequence code example
Try to use the saffron function and define you pulse sequence in Exp.Flip, Exp.t, Exp.tp and Exp.Inc. See the documentation for saffron for details.
