Support for non-Bruker file formats
Posted: Fri Oct 03, 2014 8:30 am
I am extending eprload() and implementing support for spectrometer files from vendors beyond Bruker. Currently, Adani, Active Spectrum, and magnettech are implemented. JEOL is on its way. If all goes well, this new functionality will be part of the next ES release.
If you have any spectrometers from these vendors, please send some example files so I can test the code. I am happy to share the beta version of eprload() if you can use and test it.
Re: Support for non-Bruker file formats
Posted: Wed Dec 17, 2014 6:29 pm
by Morgan Bye
SPECMAN
Very up-to-date (having used SpecMan for the last year)
https://github.com/morganbye/EPRtoolbox ... cManRead.m
JEOL
Not used in a long time
https://github.com/morganbye/EPRtoolbox ... JeolRead.m
VARIAN
Old and rather infrequently used - but used with success, yours is probably now better
https://github.com/morganbye/EPRtoolbox ... rianRead.m
Posted: Fri Dec 19, 2014 12:13 am
Thanks Morgan!
Posted: Tue Feb 17, 2015 11:43 am
by Matt Krzyaniak
Recently I've been working with some specman data files(I just got an instrument running specman back up and running) and sadly Morgan's script for loading in specman files doesn't cover all the bases.
Previously in the lab here they were using Kazan viewer, anyway I went in and pulled out the various code bits, compiled them into a single multifunction mfile, and added a gui prompt for no inputs.
function varargout=d01read(varargin)
%  d01read Read data from .d01/.exp SpecMan data files
%   data = d01read(filename,...)
%   [ax,data] = d01read(filename,...);
%   [ax,data,dsc] = d01read(filename,...);
%   Reads data and axis information from Bruker
%   files  DSC/DTA  and  PAR/SPC.   Aditional
%   arguments  are  always  coming  in pairs
%   field, value. Fields are:
%     'Dataset', [real dataset, imag dataset]
%   ax contains fields x,y,z  depends on data
%   dimension and may contain other fields as
%   well. dsc is a cell array  of description
%   strings.
% Original code by Boris Epel & Alexey Silakov
% MPI of Bioinorganic Chemistry, Muelhaim an der Ruhr, 2003
% Free for non-commercial use. Use the program at your own risk.
% The authors retains all rights.
% Contact: epel@mpi-muelheim.mpg.de
if ~nargin
    [name,path] = uigetfile('*.d01','Load Specman File');
    if ~ischar(name)
        varargout(1:nargout) = {[]};
        return;
    fname = fullfile(path,name);
    dscname=strrep(fname, 'd01', 'exp');
else
   [path,name] = fileparts(varargin{1});
   fname = fullfile(path,[name,'.d01']);
   dscname = fullfile(path,[name,'.exp']);
fid=fopen(char(fname),'r', 'ieee-le');
if fid<1, error(['File ''',fname,''' can not be open for read.']);end
ndim1=fread(fid, 1,'uint32');       % number of headers, re/im etc.
dformat=fread(fid,1,'uint32');     % format:0-double,1-float
if dformat==1
  sformat='float32';
else
  sformat='double';
dstrms = {};
ntotal = 1;
for k=1:ndim1
  ndim2       = fread(fid,1,'int32');
  dstrms{end+1}.dim = fread(fid,4,'int32');
  dstrms{end}.dim(ndim2+1:end) = 1;
  dstrms{end}.first = ntotal;
  dstrms{end}.total = fread(fid,1,'int32');
  ntotal = ntotal + dstrms{end}.total;
tmpdat=fread(fid,ntotal,sformat);
fclose(fid);
switch(ndim1)
    case 0,
        error('No data present');
    case 2,
        spec=tmpdat(dstrms{1}.first:(dstrms{1}.first+dstrms{1}.total-1))+...
            1i*tmpdat((dstrms{2}.first:dstrms{2}.first+dstrms{2}.total-1));
        spec=reshape(spec,dstrms{1}.dim');
    case 1,
        spec=reshape(tmpdat,dstrms{1}.dim');
    otherwise,
        %% find if all data have the same dimensions
        dim = dstrms{1}.dim;
        isthesame = 1;
        is1D      = (sum(dim~=1) == 1);
        for k=2:ndim1
            if sum(dim == dstrms{k}.dim) ~= 4,
                isthesame = false;
                break;
            elseif is1D && sum(dstrms{k}.dim~=1)~=1
                is1D = false;
        if isthesame && is1D,
            % read all as columns
            xdim = dim(dim~=1);
            spec=reshape(tmpdat, xdim, ndim1);
        else
            spec=tmpdat;
dsc = SpecMandsc(dscname);
ax = SpecManpar(dsc);
if ~isfield(ax, 'x') || size(ax.x, 1)~=size(spec, 1)
  ax.x = [1:size(spec, 1)];
ax.type = 'data';
if isfield(dsc,'general_freq1')
    ax.freq1 = kvgetvalue(dsc.general_freq1);
% assign output depending on number of output arguments
% requested
switch nargout
 case 1,
   varargout = {spec};
 case 2,
   varargout = {ax, spec};
 case 3,
   varargout = {ax, spec, dsc};
return
function par = SpecMandsc(filename)
h = fopen(filename);
if h<0
  disp('Description file was not found.');
  par = [];
  return;
olda = '';
par = [];
forbidden = '~!@#$%^&*()./\';
section = '';
text = 1; prg = 1;
while feof(h)<1
  s = strtrim(fgetl(h));
  if isempty(s), continue; end;
  sect = find(s=='[' | s==']');
  %   this is a section header
  if size(sect, 2)==2 && sect(1)==1
    section = s(sect(1)+1:sect(2)-1);
%     par = setfield(par, section, 'section');
  else
    switch section
      case 'text'
        par = setfield(par, ['text', num2str(text)], s);
        text = text + 1;
      case 'program'
        par = setfield(par, ['prg', num2str(prg)], s);
        prg = prg + 1;
      otherwise
        [a,s]=strtok(s, '=');
        a = strtrim(a);
        a(a=='/' | a=='\' | a==' ')='_';
        par = setfield(par, [section,'_',a], s(2:end));
fclose(h);
return
function res = SpecManpar(par)
prefix = ['n', 'u', 'm', 'k', 'M', 'G'];
koeff  = [1E-9, 1E-6, 1E-3, 1E3, 1E6, 1E9];
res.title = safeget(par, 'general_name', '?');
sweepax = {};
key = 'transient';
fullfield = ['sweep_', key];
idx = 0;
triggers = str2num(safeget(par, 'streams_triggers', '1'));
while isfield(par, fullfield)
    [ax.t, str] = strtok(getfield(par, fullfield), ',');
    ax.t = strtrim(ax.t);
    [ax.size, str] = strtok(str(2:end), ',');
    if ax.t=='S' || ax.t=='I' || ax.t=='A' || ax.t=='R', ax.size = 1; else ax.size = str2num(ax.size); end
    [ax.reps, str] = strtok(str(2:end), ',');
    ax.reps = str2num(ax.reps);
    ax.var = {};
    while ~isempty(str)
        [ax.var{end+1}, str] = strtok(str(2:end), ',');
    sweepax{end+1,1} = ax;
    fullfield = ['sweep_sweep', num2str(idx)];
    idx = idx +1;
sweepax{1}.size=sweepax{1}.size*triggers;
res.sweepax = sweepax;
axislabel = ['xyz'];
counter = 1;
for k = 1:size(sweepax, 1)
    arr = [];
    asize = sweepax{k}.size;
    if asize > 1
        switch sweepax{k}.t
            case {'I', 'A'}
                tempparam = 'trans';
                par.params_trans = '1sl step 1sl;';
            case 'T'
                dwell_time_str = safeget(par, 'streams_dwelltime', '1 ns');
                dwell_time_str = strtrim(gettoken(dwell_time_str, ','));
                par.params_trans = ['0 ns step ', dwell_time_str,';'];
            otherwise
                tempparam = sweepax{k}.var{1};
                tempparam(strfind(tempparam, ' ')) = '_';
        % check if this is a parameter
        if isfield(par, ['params_', tempparam])
            str = getfield(par, ['params_', tempparam]);
            if ~isempty(strfind(str,'step'))
                [tk1, str1] = gettoken(str, 'step');
                % string of the type 10ns step 6 ns
                tk2 = strtrim(gettoken(str1, ';'));
                [minval, unit] = kvgetvalue(tk1);
                step = kvgetvalue(tk2);
                arr = [0:asize-1]*step+minval;
            elseif ~isempty(strfind(str,'logto'))
                [tk1, str1] = gettoken(str, 'logto');
                % string of the type 10ns logto 60 ns
                maxval = kvgetvalue(tk2);
                arr = logspace(log10(minval), log10(maxval),asize);
            elseif ~isempty(strfind(str,'to'))
                [tk1, str1] = gettoken(str, 'to');
                % string of the type 10ns to 60 ns
                arr = [0:1/(asize-1):1]*(maxval-minval)+minval;
            else
                % string of the type 10ns, 20ns, 30ns;
                [str1] = gettoken(str, ';');
                [tk1, str1] = gettoken(str1, ',');
                while ~isempty(tk1)
                    [arr(end+1),unit] = kvgetvalue(tk1);
                    if isempty(tk1) && ~isempty(str1)
                        tk1 = str1; str1 = [];
        else
            str = getfield(par, ['aquisition_', tempparam]);
            arr = [0:asize-1]';
            unit = 's';
        % Unit normalization
        switch unit
        case 'G',
        case 'K',
        case 's',
        otherwise
        umax = max(abs(arr));
        for kk = length(koeff):-1:1
            if umax > koeff(kk)
                uk = koeff(kk);
                unit = [prefix(kk), unit];
                arr = arr./uk;
                break;
        res = setfield(res, axislabel(counter), arr');
        res = setfield(res, [axislabel(counter), 'label'], ...
            [sweepax{k}.var{1}, ', ',unit]);
        counter = counter + 1;
return
function [tk,rstr] = gettoken(istr, tok)
pos = strfind(istr, tok);
if isempty(pos)
    tk=istr;
    rstr='';
else
    tk=strtrim(istr(1:pos-1));
    rstr=strtrim(istr(pos+length(tok):end));
return
function res = safeget(strct, fld, deflt)
% function res = safeget(strct, fld, deflt)
% Returns the field of the structure or default
% value if field is absent.
% if default value is array then return value
% has not less elements than in this array
% (not in char case)
if isfield(strct, fld)
    res = getfield(strct, fld);
    sd = size(deflt, 2);
    sr = size(res, 2);
    if sr < sd
        if iscell(deflt)
            [res{sr+1:sd}] = deal(deflt{sr+1:sd});
        elseif ~ischar(deflt)
            res(sr+1:sd) = deflt(sr+1:sd);
else
    res = deflt;
return
function [val, unit, pref, pref_val] = kvgetvalue(str)
% KVGETVALUE read string value in ci-standard units
% [val, str_unit, str_koefficient] = kvgetvalue(str)
prefix = ['p','n', 'u', 'm', 'k', 'M', 'G', 'T'];
koeff  = [1E-12, 1E-9, 1E-6, 1E-3, 1E3, 1E6, 1E9, 1E12];
idx = (str >= '0' & str <='9') | str == '.' | ...
    upper(str) == 'E' | str == '+' | str == '-';
pref = '';
pref_val = 1;
val = str2num(str(idx));
unit = str(~idx);
unit = unit(unit~=' ');
if length(unit) > 1
    if ~isempty(unit)
%         kk = findstr(prefix, unit(1));
          kk = strfind(prefix, unit(1));
        if ~isempty(kk)
            val = val * koeff(kk);
            unit = unit(2:end);
            pref = prefix(kk);
            pref_val = koeff(kk);
return
Just as a check, I've uploaded a complex 2D dataset(pretty much just noise). eprload just pulls in the z data, Morgans script was only pulling in the real part of the data and the time(x-axis), not the field.
Posted: Mon Feb 23, 2015 12:26 pm
Thanks Matt. ES should definitely do a better job of importing specman files! Goes on my to-do list.
