Simulation of copper acetate
Hi all
I am trying to simulate the X-band 279 K spectrum for copper acetate which results from the di-nuclear copper acetate's antiferromagnetic coupling. How can I go about doing this? I will attach the research paper this comes from here:
https://pmc.ncbi.nlm.nih.gov/articles/PMC10572876/
I assume that this example script from the easy spin website is a good starting point due to the coupled spins:
% Two coupled electrons
clear, clf
% Two-electron system, both electrons with rhombic g tensor
Sys.S = [1/2 1/2];
Sys.g = [2 2.05 2.1; 2.2 2.25 2.3];
Sys.lwpp = 1;
% Electron-electron couplings
Sys.J = 50; % isotropic coupling, in MHz
Sys.dip = 100; % axial dipolar coupling, in MHz
% X band conditions
Exp.mwFreq = 9.5; % GHz
Exp.Range = [280 350]; % mT
pepper(Sys,Exp);
title('Two dipolar coupled orthorhombic S=1/2');
The research paper also provides the zero splitting parameters D and E So I assume incorporating these into the script will be necessary as well.
