orca2easyspin error
Posted: Thu Sep 12, 2024 12:46 pm
by jacott.caius
I am trying to import a spin system from an ORCA 6.0. Whenever I use orca2easyspin, I get the following error:
Unable to perform assignment because the indices on the left side are not compatible with the size of the right side.
Error in orca2easyspin_maintxt
I have tried to read from .oof, .out, .txt, .prop files and all have the same error.
I have also attempted to read from the .property.txt file & get the following error:
Error using orca2easyspin
orca2easyspin() currently does not support reading spin Hamiltonian parameters from _property.txt files. Provide the main output
file instead.
Right now I've put aside the fancy molecules and I'm just following the Hydroxyl simulation provided in the easyspin documentation for orca2easyspin. Attached are the relevant files.
Please advise.
Re: orca2easyspin error
Posted: Thu Oct 10, 2024 5:02 pm
This should be fixed now in EasySpin 6.0.6. Prior to that version, EasySpin did not support ORCA 6 output files.
