Seeking suggestions to fit EPR spectrum of a Fe(III) complex having both high-spin and low-spin components
We conducted an Electron Paramagnetic Resonance (EPR) spectroscopy analysis on a Fe(III) complex in frozen methanol at 6K, revealing a combination of high-spin and low-spin components associated with the Fe3+ complex ion. While we satisfactorily modelled the low-spin component (g ~ 2), the high-spin portions (g ~ 4.3) fitting proved challenging, with the intensity of the fitted spectral line not aligning well with the experimental one.
Our simulation utilized the pepper function, incorporating zero-field splitting (D) and E/D parameters to simulate the high-spin components. Additionally, we employed a two-component system to fit the overall spectrum for the iron complex. Attached herewith are the Matlab script and the spectrum fitted thus far. We welcome any suggestions to improve and refine the fitting process.
[B,spc] = textread('FeLHH2O.txt','%f %f');
Exp.mwFreq = 9.64; % GHz
Exp.Range = [min(B) max(B)]; % mT
Exp.nPoints = numel(B);
Exp.Temperature = 6; % temperetaure in Kelvin
Opt.nKnots = 10;
Opt.Transition = [1 2]; % level 1 <-> level 2
Sys1.S = 5/2;
Sys1.Nucs = 'Fe';
Sys1.g = [2.05 2.03 2.01];
Sys1.A = [1]; % MHz
Sys1.D = [9650 9650*0.28]; % MHz
Sys1.lwpp = [3 13]; % mT
Sys1.weight = 90; % percentage
Vary1.g = [0.01 0.01 0.01];
Vary1.D = [500 9650*0.05];
Vary1.lwpp = [1 2]; % mT
Sys2.S = 1/2;
Sys2.Nucs = 'Fe';
Sys2.g = [2.13];
Sys2.A = [1]; % MHz
Sys2.D = 0; % MHz
Sys2.lwpp = [2 9]; %mT
Sys2.weight = 10; % percentage
Vary2.g = [0.02];
Vary2.D = 0;
Vary2.lwpp = [1 2]; %mT
plot(B,(spc/max(spc)));
pepper({Sys1,Sys2},Exp,Opt);
esfit(@pepper,spc,{Sys1,Sys2},{Vary1,Vary2},Exp,Opt);
