unable to run "pepper" on R2014_a
archana.tiwari
Re: unable to run "pepper" on R2014_a
Post by archana.tiwari »
Thank you. I tried as mentioned (using Opt.Sparse=1 and Opt.Verbosity =2 ) and following is the output message:
>> eespins
single spin system
component 1: 1 isotopologues
=begin=pepper=====14-Feb-2018 10:59:21=================
log level 2
-general-----------------------------------------------
system with 2 spin(s) and 4 states
field sweep, mw frequency 9.5 GHz
frequency 9.5 GHz, field range [280 350] mT, 1024 points
harmonic 1, mode
no temperature
-orientations------------------------------------------
powder sample (randomly oriented centers)
Error using eig
Out of memory. Type HELP MEMORY for your options.
Error in symm>symm_full (line 256)
Error in symm (line 118)
Error in p_symandgrid (line 14)
Error in pepper (line 566)
Error in pepper (line 159)
Error in eespins (line 19)
pepper(Sys,Exp,Opt);
I'm not familiar with MacOS, but it looks that there is too low memory allocated for MATLAB process in Your system.
UPD. This script may help to find available memory limit. https://gist.github.com/wouterpotters/c ... acc3bcae4f
archana.tiwari
Thanks again. I have switched to my old PC for the simulation and it works fine there. Perhaps, the problem is with Matlab on OSX.
