effective spin-system and pseudonuclear effects with saffron
lorenz
Post by lorenz »
I would like to simulate orientation selective Hyscore on a lower kramers doublet (S=3/2) with saffron.
By using the effective rombic g-tensor values (with s'=1/2), the pseudo-nuclear Zeeman-tensor is not included. Is there a way to include this effect with saffron?
Or would it be better to calculate the real g-values + zerofield-splitting parameter from the effective g-values and run saffron with the whole S=3/2 spin-system.
In that case there should be no trouble with the pseudo-nuclear effects? Is this right?
Are there any limitation to the zerofield-splitting and electron Zeeman Hamitonian when using saffron, especially if the ZFS is much larger than the electron Zeeman?
Kind regards
lorenz
Re: effective spin-system and pseudonuclear effects with saf
I recommend running the simulation with S=3/2. It works for any size of the zero-field splitting. saffron diagonalizes the Hamiltonian without the superhyperfine nuclei to get energy levels and states which are then used to calculate orientation- and transition-selection factors. Just make sure to include Exp.mwFreq and Exp.ExciteWidth.
Unfortunately, there is no direct way in EasySpin to specify a pseudo-nuclear Zeeman term.
lorenz
Post by lorenz »
Thank you very much for your answer.
If I understand your answer correctly, the effect of pseudonuclear zeeman tensor should be included if I use the total spin hamiltonian.
So the systematical error should be smaller instead of using the fictitious spin system.
Is this correct?
Kind regards
lorenz
That's correct!
lorenz
Post by lorenz »
Thanks a lot for your quick answer
lorenz
Post by lorenz »
Dear easyspin team,
I've tried to simulate the follwowing Spin-System:
S=3/2; g=[2.00 2.03]; D=[1 0.053]*12.2*cm^-1, (This correspondes to a ficticous S'=1/2-System with: g'=[4.31 3.67 2.01]
I want to Simulate the Hyperfine couplings of two nulcei on the lower kramers doublet.
By computing the Spectra (3PESEEM and Hyscore) with saffron (S=3/2-System), there occous additional lines at higher frequnencies. I would not ecpect these frequencies by simulation with a ficticous Spin-System S'=1/2.
Are these the transitions of the higher Kramers doublet? Does saffron calculatetes all possible transitions between all possible Subhamiltionias? Or is always the asumption done, that only the lowest spin-state is populated?
If its so: Is it possible to force saffron to only one transition?
Kind regards
lorenz
Please post a short self-contained script that demonstrates what you are describing.
lorenz
Post by lorenz »
Dear Easyspin-Team,
here is my easyspin-input, its an example on g~2 in X-Band:
%Define Experiment 3PESEEM (ideal Pulses):
Exp.mwFreq=9.70;
Exp.Field=341.8;
Exp.T=0.4;
Exp.tau=0.13;
Exp.dt=0.020;
Exp.Sequence='3pESEEM';
Exp.ExciteWidth=1000/16; %Orientationselection ~60MHz
Exp.nPoints=1024;
%Define System1:
%real Spin System: S=3/2
Sys1.S=3/2;
Sys1.g=[2.00 2.03];
Sys1.D=[1 0.053]*12.2*10^4*3; %D=12.2cm^-1 E/D=0.053
Sys1.Nucs='13C,13C';
Sys1.A=[1.2 2.8 2.9;0.4 1.7 -1.5]; %real HFS
%Define System2:
%ficticous Spin-System S'=1/2
Sys2.S=1/2;
Sys2.g=[3.67 4.31 2.01];
Sys2.Nucs='13C,13C';
Sys2.A=[1.2*3.67/2 2.8*4.31/2 2.9;0.4*3.67/2 1.7*4.31/2 -1.5]; %HFS ficticous Ai'=Ai*g'i/g g~2
%Define Options:
Opt.nKnots=181;
Opt.TimeDomain=0;
Opt.Window='ham+';
Opt.ZeroFillfactor=2;
figure(1)
saffron(Sys1,Exp,Opt);
figure(2)
saffron(Sys2,Exp,Opt);
%The expected peaks look quite similar, but there appear additional peaks at 6,5MHz and 10MHz when I use the Full Hamiltonian.
%Might this be the upper Kramers doublet?
% Easyspin-Verion: 5.0.15
% Matlab-Version: 2013b
%Thanks you for your help
lorenz
Post by lorenz »
Add:
I have alread checked both Spin-System with a simulated cw-Experiment ('pepper'), they look similar.
lorenz
Post by lorenz »
Add:
I'm quit sure, that the additional peaks are due to the upper Kramers doublet.
If you add the follwoing spin-system:
%Define System3:
%ficticous Spin-System S'=1/2 upper doublet
Sys3.S=1/2;
Sys3.g=[0.34 0.32 6];
Sys3.Nucs='13C,13C';
Sys3.A=[1.2*0.34/2 2.8*0.32/2 2.9*6/2;0.4*0.32/2 1.7*0.34/2 -1.5*6/2]; %HFS ficticous Ai'=Ai*g'i/g g~2
%Define Options:
Opt.nKnots=181;
Opt.TimeDomain=0;
Opt.Window='ham+';
figure(3)
saffron(Sys3,Exp,Opt);
By weighting the FFT-spectra of the lower and upper Kramers doublet, it looks similar to the data for the of the real S=3/2 Spin System.
So I think there is a significant mixure of the Levels.
How can I aviod this?
Is there a way to force saffron to lower initial state?
For example with the temperature for the inital density-matrix?
Kind regard
lorenz
