JamesS
Posts: 2 Joined: Wed Mar 24, 2021 9:32 am
Post
by JamesS » Wed Mar 24, 2021 9:41 am
For CW simulation, if I don't state the isotope and give one hyperfine value how does Easyspin assign the hyperfine values? For example, if I write Cu and give it a value of 150 MHz. What hypefine values will Easyspin assign to 63Cu and 65Cu?
Thank you and best wishes,
James
trukhan
Posts: 11 Joined: Sun Jan 15, 2017 12:18 am
Post
by trukhan » Thu Apr 01, 2021 8:59 pm
Hello!
If you set A = 150 MHz and Nucs = 'Cu' then EasySpin will assign
A(63Cu) = 150 MHz
A(65Cu) = 150 MHz * nucgval ('65Cu') / nucgval ('63Cu') = 150 MHz * 1.5878 / 1.4824 = 160.7 MHz
You can understand this from the following example:
% Component 1
Cu63.g = [2.000 2.100];
Cu63.A = [mt2mhz(1,Cu63.g(1)) mt2mhz(5,Cu63.g(2))]; % MHz
Cu63.Nucs = '63Cu';
Cu63.lwpp = 0.3; % mT
% Component 2
Cu65.g = Cu63.g;
Cu65.A = Cu63.A*nucgval('65Cu')/nucgval('63Cu'); % MHz
Cu65.Nucs = '65Cu';
Cu65.lwpp = Cu63.lwpp; % mT
% Natural abundance
Cu.g = Cu63.g;
Cu.A = Cu63.A; % MHz
Cu.Nucs = 'Cu';
Cu.lwpp = Cu63.lwpp; % mT
% Relative abundances
Cu63.weight = nucabund('63Cu');
Cu65.weight = 1-Cu63.weight;
Cu.weight = 1;
% Experimental parameters
Xband.mwFreq = 9.773; % GHz
Xband.Range = [320 355]; % mT
[B,s1]=pepper(Cu63,Xband);
[B,s2]=pepper(Cu65,Xband);
[B,s3]=pepper(Cu,Xband);
shiftY=0;
plot(B,s1,'r',B,s2,'b',B,s1+s2+10,'k',B,s3+11,'g'); axis tight
legend('^6^3Cu','^6^5Cu','69% ^6^3Cu + 31% ^6^5Cu','Cu','Location','northwest');
grid on;
set(gca,'xtick',[325:5:355]);
JamesS
Post
by JamesS » Fri May 07, 2021 5:49 am
Thanks a lot for your work on this.
I assume the reference point is always the isotope with the greater natural abundance? Then, as you have shown, it scales with nuclear g value.
Posts: 1127 Joined: Mon Jul 21, 2014 10:11 pm
Post
by Stefan Stoll » Thu May 20, 2021 10:11 pm
Yes, correct. For hyperfine couplings, it's the most-abundant isotope. This is documented on the page about spin system, for Sys.Nucs
