Fitting roadmap
Fitting roadmap
How do we fit a roadmap to data to extract parameters such as gx, gy, gz etc? Attached is an example of the experimental data (symbols) and simulation of a roadmap. Line represents simulation, not a fit to the data.
- Picture1.png (42.09 KiB) Viewed 3986 times
Re: Fitting roadmap
Use
esfit
with a custom function, say mysim
. This function should call resfields
to calculate the resonance fields for all the orientations where you have experimental data. As data for esfit
, supply the list of experimental field values.Re: Fitting roadmap
As a follow-up question, when the spectrum has several overlapping resonances and broad lines, the precise position of each resonance may not be possible to extract.
In such a case, wouldn't it be easier (or rather the only option) to just fit each single-crystal spectrum?
Re: Fitting roadmap
Yes, for spectra with overlapping peaks, fitting the spectra as opposed to peak positions is usually more convenient.
