Hyperfinesplitting drawing program
moreutz
Post by moreutz »
I would like to draw diefferent splitting schemes like in the picture (
Splitting scheme DMPO.PNG (26.96 KiB) Viewed 13642 times
Does anyone know a program to create them?
Best regards
moreutz
Re: Hyperfinesplitting drawing program
You may try this script. Just change the spin system as You want.
clear, clf
Sys.g = 2;
Sys.Nucs = '14N,1H,1H';
Sys.lw = [0,0.02];
Sys.A = [10; 5; 2]; % MHz
Sys.n=[2 1 4];
Exp.Range=[343 347];
Exp.mwFreq = 9.65;
Exp.nPoints=4096;
Exp1=Exp;
Exp1.Harmonic=0;
Opt.Method='perturb1';
nspin=numel(Sys.A);
for i=0:nspin
    if i>0
        Sys1=nucspinkeep(Sys,1:i);
    else
        Sys1=nucspinrmv(Sys,1:nspin);
    Sys1=rmfield(Sys1,'lw');
    yy=garlic(Sys1,Exp1,Opt);
    yy=yy/max(yy);
    y(:,i+1)=yy;
[x,yy]=garlic(Sys,Exp,Opt);
yy=yy/max(yy);
y(:,nspin+2)=yy;
stackplot(x,y,1,1.1);
This script draws splitting scheme as on the picture. Just define required spin system and correct field range. Equivalent nuclei and isotope mixtores does not supported yet.
clear, clf
% Parameters
% Spin system
Sys.g=gfree;
Sys.Nucs='14N,14N,1H';
Sys.A=[10 12 5];
Sys.lwpp = [0,0.02]; % Lorentzian lines
Exp.CenterSweep = [339.4, 2];
Exp.nPoints = 4096;
Exp.mwFreq=1e-3*mt2mhz(Exp.CenterSweep(1),mean(Sys.g));
% Simulations
[xa,ya] = garlic(Sys,Exp);
% Diagram calculation
if isfield(Exp,'Range'), dx=1/mt2mhz(max(Exp.Range)-min(Exp.Range),mean(Sys.g));end
if isfield(Exp,'CenterSweep'), dx=1/mt2mhz(Exp.CenterSweep(2),mean(Sys.g));end
nNucGroups=0;
if ~isempty(Sys.Nucs)
  I = nucspin(Sys.Nucs);
  nNucGroups = max(size(Sys.A));
  dy=1/(1+3*nNucGroups);
  if numel(I)~=nNucGroups, error('Sys.A and Sys.Nucs are not consistent.'); end
set(gcf,'Color','w');
axes('Position', [0 0 1 1]);
plot(xa,ya,'k');
axis off;
axis([min(xa) max(xa) min(ya)*(1+2*nNucGroups) max(ya)]);
y=0;
x=[0.5];
annotation ('line',[x x],[y dy]); %first line
y=y+dy;
for i=1:nNucGroups
    mI = -I(i):I(i);
    x2=[];
    for j=1:numel(x)
        x1=x(j)+dx*Sys.A(i)*mI;
        for k=1:numel(x1)
            annotation ('line',[x(j) x1(k)],[y y+dy],'LineStyle',':'); %splitting line
            annotation ('line',[x1(k) x1(k)],[y+dy y+2*dy]); %next line
       x2=[x2 x1];
    x=x2;
    y=y+2*dy;
Nice!
The support for equivalent nuclei is added.
clear, clf
% Parameters
% Spin system
Sys.g=gfree;
Sys.Nucs='14N,1H';
Sys.A=[10 0.6];
Sys.n=[2 12];
Exp.nPoints = 4096;
% Simulations
nNucGroups=0;
  if isfield(Sys,'n')&&max(Sys.n)>1 %equiv nucs
      for i=1:numel(Sys.n)
          if Sys.n(i)>1
              [I1,~]=equivcouple(I(i),Sys.n(i));
              I(i)=I1(1);
plot(xa,ya,'k');
axis off;
axis([min(xa) max(xa) min(ya)*(2.5+2*nNucGroups) max(ya)]);
y=0;
x=[0.5];
y=y+dy;
for i=1:nNucGroups
    mI = -I(i):I(i);
    x2=[];
    for j=1:numel(x)
        for k=1:numel(x1)
       x2=[x2 x1];
    x=x2;
    y=y+2*dy;
moreutz
Post by moreutz »
Thank you very much!
Unfortunately I have an natural isoptope mixture (Sys.Nucs = 'N,H')..
moreutz wrote:Thank you very much!
For both N and H you generally don't need to worry about natural isotope mixtures, as their isotope abundances <<1%.
moreutz
Post by moreutz »
This is my input:
Sys.A = mt2mhz([1.49 1.49]);
Sys.g = 2.005;
Sys.lwpp = [0 0.12];
Sys.Nucs = '14N,1H';
Sys.n= [1 1];
Exp.mwFreq = 9.44;
Exp.nPoints = 4096;
Exp.Range = [331 342]
So I get this diagram:
Aufspaltungsmuster DMPO-OH.jpg (30.73 KiB) Viewed 13566 times
Why isn't it correct?
The diagram starts drawing from the center of the figure. The spectrum have to be centered too. It may be forced by either Exp.mwFreq=1e-3*mt2mhz(Exp.CenterSweep(1),mean(Sys.g)); or Exp.mwFreq=1e-3*mt2mhz(mean(Exp.Range),mean(Sys.g)); depending how You prefer define the field range.
Sorry, this is indeed unclear moment.
moreutz
Post by moreutz »
Perfect, thanks a lot! :)
