Is the possibility of using the circular polarization of mw, when simulating cw spectra, still allowed in ES? I remember this was introduced in a previous version of ES (5.0.0, as from release notes) but in the documentation of the current release there is no indication about this, and only 'perpendicular' or 'parallel' are mentioned as possible values of Exp.Mode.
Thanks in advance for any clarification
Circular polarization
Re: Circular polarization
The syntax has changed, polarization is no specified in
Exp.mwPolarization
. See here.Re: Circular polarization
Thanks a lot!
