pepper, 3d plot of Spec in terms of Gaussian and Lorentz lw
Sharon
Post by Sharon »
Dear experts,
I have a question. I want to simulate cw EPR and compare with my experiment result. To find the optimal linewidth, I want to simulate spec as a function of both Gaussian and Lorentz linewidth, but when I use two for loops to vary both linewidth, there was an error, says No broadening given, cannot compute spectrum with Exp.Harmonic=1. I am wondering if easyspin pepper cannot support to vary both linewidth?
Sharon
joscha_nehrkorn
Re: pepper, 3d plot of Spec in terms of Gaussian and Lorentz
Post by joscha_nehrkorn »
The error you reported here might be because at some point in your double loop both line widths were zero. EasySpin needs a finite line width to calculate a derivative spectrum.
Anyhow, you might be better of in fitting the line width using esfit.
If you post a short script that generates the error, it will be easier to help you.
