Simulation of biradicals in hybrid mode
I have found that simulation of the spectrum of biradicals by pepper function gives wrong results with Opt.Method='hybrid' parameter. The spectra always looks as ones with J>>A regardless Sys.J parameter. Here the script illustrating the problem.
clear, clf
aN=28;
J=aN*[0.01 0.3 0.5 0.9 1.5 2 2.5 3.5 5 7 9 12 20 40 1000];
Exp.mwFreq =9.66;
Exp.Range = [338 350];
Sys.S = [1/2 1/2];
Sys.Nucs='14N,14N';
Sys.A=mt2mhz([aN 0.0;0.0 aN;]/10);
Sys.g = [2.0060; 2.0060];
Sys.lw = [0 0.15];
Exp.nPoints=4096;
Opt.Method='hybrid';
for i=1:numel(J)
Sys.J=J(i);
FitOpt.Scaling = 'maxabs';
[x,y1(i,:)]=pepper(Sys,Exp,Opt);
stackplot(x,y1,1,1);
Is it a bug or restriction of hybrid method?
nwili
Re: Simulation of biradicals in hybrid mode
Post by nwili »
Not sure if this is a bug. The documentation says:
" 'hybrid' indicates matrix diagonalization for all the electron spins, and perturbation treatment for all nuclei"
In the case of exchange coupling, the first step, i.e. the diagonalization for the electron spins, will always lead to a singlet-triplet basis in the absence of hyperfine interaction (and identical g-values).
nwili is right. Here is a brief demonstration script:
Sys.S = [1/2 1/2];
Sys.J = 0.01;
H = sham(Sys,[0 0 350]);
[V,E] = eig(H)
V shows complete mixing of the |alpha,beta> and the |beta,alpha> states, no matter how small J is.
