I input the command : Sys=orca2easyspin('filename');
in matlab editor and run it. but i can't get a right result, it reports a error:
Error using orca2easyspin
Unknown property encountered (PropertyID = 757935405)
the file directory was checked. no matter how i use orca2easyspin('filename') or orca2easyspin('filename.prop') or orca2easyspin('filename.out'),same error report occurs.
who can give me the answer?
the toobox version is :5.2.35.
cannot import data from orca output though orca2easyspin
- Newbie
- Newbie
Re: cannot import data from orca output though orca2easyspin
my orca version is 5.0.4. whether the error comes from orca version mismatches the easyspin?
EasySpin 5.2.x does not support ORCA 5.0.x
Please use EasySpin 6 instead.
