New esfit does not recognize FitOpt.Baseline argument
Posted: Sun Mar 12, 2023 12:01 am
by thanasis
Using FitOpt.Baseline = 0, 1, 2, 3, or 4 is not recognized by the GUI window.
The esfit window always starts from "Baseline none" and the baseline type needs to be manually defined.
This is in version 6.0.0-dev.51
Re: New esfit does not recognize FitOpt.Baseline argument
Posted: Wed May 10, 2023 11:43 am
This could be a capitalization issue. Try FitOpt.BaseLine instead of FitOpt.Baseline.
Posted: Tue Aug 29, 2023 7:16 am
by thanasis
Yes, that was the issue!
I believe a correction should be made at the esfit documentation page downloaded with the latest version.
Thanks Stefan.
Posted: Sat Sep 02, 2023 11:40 pm
We will fix the documentation - thanks for pointing this out!
Posted: Mon Sep 04, 2023 3:55 am
by thanasis
In a (probably) related issue, FitOpt.PrintLevel seems to have no effect on the output's verbosity when esfit is invoked without the fitting GUI. Even setting to 0 produces the full output.
I have tried capitalization permutations (printLevel, Printlevel, printlevel) without luck.
Posted: Tue Mar 26, 2024 10:28 pm
In version 6, this has been renamed to Verbosity, to be more consistent with other EasySpin functions.
