Calculated spectrum is 0 for narrow range
christiansen
Post by christiansen »
Dear Easyspin community
Today I discovered a bug. I was able to simulate a full spectrum (0-15.8 T) very well using 'pepper'. However, when I try to only simulate a narrow range (15.5-15.8 T) 'pepper' returns nothing but zeros instead of something similar to what I got for the broad simulation. Am I doing something wrong? See code below. I run Easyspin 5.2.35 in Matlab R2019b on Ubuntu 18.04.
clear all
rcm = 29979.2458; % reciprocal cm to MHz
Sys.S = [9/2];
D = 1.15*rcm;
E = 0.31*rcm;
Sys.D = [D E];
Sys.g = [2 2 2];
Sys.B4 = -2e-4*rcm;
Sys.lwpp = [0 100];
Sys.DStrain = abs(Sys.D)*0.05;
Exp.nPoints = 729; %For narrow spectrum
Exp.mwFreq = 331.2;
Bmax = 15.8; %in T
Exp.Range = [15.5 15.8].*1000; % in mT
Exp.Temperature = 18; %in K
[BSim,spcSim] = pepper(Sys,Exp); %spcSim is full of zeros when narrow range is simulated. When full range is simulated there is intensity in the narrow range.
% Opt.nKnots = 91;
% [BSim,spcSim] = pepper(Sys,Exp, Opt); %spcSim is full of zeros when narrow range is simulated. When full range is simulated there is intensity in the narrow range.
Re: Calculated spectrum is 0 for narrow range
Interesting, we'll look into that. Your script errors, can you please post one that runs clean so we can reproduce the problem?
This is problem with the number of orientations, using the default number of nKnots or GridSize there are effectively no transitions in the chosen range. Increase that value and your reduced range and overall spectrum will look considerably better.
christiansen
Thanks for your replies
@Stefan: The code does not give any errors; the returnt array spcSim is simply full of 0. Besides that, the code runs, and no error messages are given. I corrected a few typos I my original post and it should run now.
@Matt: That sounds like a reasonable explanation. In fact, increasing the number of knots solved the problem!
In the updated code example in my original post, the code now runs as it should when pepper is run with Opt.nKnots = 91.
Excellent. Quick note: if you switching over to version 6, remember to use Opt.GridSize instead of Opt.nKnots. The syntax has changed between versions 5 and 6.
