Transition probabilities vs turning angles
Posted: Thu Nov 10, 2022 5:16 pm
by thanasis
For the calculation of transition intensities I understand that Easyspin considers the transition probabilities, the Boltzmann polarization and (for field sweeps) the Aasa-Vänngård 1/g correction.
However, when pulsed field-swept spectra are concerned, it has been pointed out (e.g. by Eaton & Eaton) that the intensity of an echo will depend on the turning angle of that transition under the particular B1 field, which in turn will depend on the spin manifold(s) within (or between) which it occurs. This will influence the spectral shape.
If this turning angle is strictly equivalent to the above consideration of the quantum-mechanical transition probabilities, then the integration of the derivative spectrum (e.g. by pepper) should be sufficient. Is this the case, however?
Moreover, can pepper include in its calculation the MW power to simulate the transition intensities either CW, or echo-detected?*
*Of course, the MW power in CW spectra is related to saturation and T1. However, assuming an isotropic T1, saturation should influence the total intensity and not the individual resonances.
Re: Transition probabilities vs turning angles
Posted: Tue Nov 15, 2022 4:51 pm
Yes, one would need to take transition-dependent flip angles into account when simulating pulse field-swept EPR spectra. pepper is not designed for this.
Also, for an echo-detected field-swept spectrum, one needs to take ESEEM effects into account - in the presence of coupled nuclei with hyperfine coupling similar to twice their Larmor frequency, echo suppression can happen, and if the hyperfine coupling is anisotropic, this can change the shape of the field-swept spectrum substantially compared to a CW EPR spectrum.
For an accurate pulse field-swept spectrum, it's best to do an explicit pulse simulation with saffron or spidyan.
Posted: Mon Feb 06, 2023 3:32 am
by thanasis
Dear Stefan,
Taking you up on your advice, I looked at the examples.
The closest one I could find was the 2pEcho simulation using the density matrix. I tried looping through various field values of a field-swept experiment, but I guess this is not what you suggest. Since the relevant part of the echo simulation does not consider the MW frequency, resonance conditions are not calculated even if the system and experiment are otherwise defined (the script at the end of the experiment).
Since saffron exports results in time (ESEEM) or frequency (ENDOR) domains, how would one go about calculating echo intensities of a simple 2pEcho experiment? "Trick" saffron during an ESEEM simulation by npoints = 1 , dt = 0 and tau = the field-sweep experiment tau? Would that be legitimate?
Thanks in advance!
Thanasis
% Simulation of a two-pulse echo using the density matrix
% Here we show how one can simulate a 2-pulse echo transient
% using the density matrix formalism. This is an example of
% advanced usage.
clear all; close all;
%% Define parameters of pulse experiment
n = 300; % signal length
dt = 0.005; % step time [�s]
FWHM = 20; % line width [MHz]
tau = 0.7; % interpulse distance [�s]
% We compute a set of 2-pulse-echo signals, differing in the length of the pulses used.
% The static Hamiltonian is not neglected during the pulse.
offset = 1.2*FWHM*linspace(-1,1,200);
weights = gaussian(offset,0,FWHM);
% Variable tp or fixed?
tp = 0.020;
% tp = 0:0.020:0.180; % pulse length [�s]
%% Define system
gx = 2.002;
gy = 2.002;
gz = 2.002;
gx1 = 2.002;
gy1 = 2.002;
gz1 = 2.002;
gx2 = 2.006;
gy2 = 2.006;
gz2 = 2.006;
r12 = 10; % In Angstrom
R12 = [0; 0; 1]; R12 = R12/norm(R12); % Directional vector between spins Mi-Mj is defined along z
J = -0.01; % In cm-1, +JSiSj formalism
% A1 = [5 5 20]; % Hyperfine S1-A1
% A2 = [10 10 80]; % Hyperfine S2-A2
A1 = 0*[5 5 5]; % Hyperfine S1-A1
A2 = 0*[40 40 40]; % Hyperfine S2-A2
A12 = [0 0 0]; % Hyperfine S1-A2
A21 = [0 0 0]; % Hyperfine S2-A1
% Spin system
Sys1.S= [1/2 1/2];
% Sys1.g=[gx gy gz; gx gy gz];
Sys1.g=[gx1 gy1 gz1; gx2 gy2 gz2];
Sys1.lwpp=[1 0];
Sys1.gFrame = [0 90 -90; 0 90 -90]*pi/180;
if sum(A1) + sum(A2) ~= 0
    % A-frames
    Sys1.A = [A1 A12; A21 A2];
    Sys1.Nucs = '14N,14N';
%     Sys1.AFrame = [Aframe1 0 0 0; 0 0 0 Aframe2;]*pi/180;
% -------------Describe local g-tensors in molecular frame-------------
% Euler angles for T->M (reverse-opposite of gFrame)
euler1 = -fliplr(Sys1.gFrame(1,:));
euler2 = -fliplr(Sys1.gFrame(2,:));
% Rotation matrices for T->M
R_T2M_1 = erot(euler1);
R_T2M_2 = erot(euler2);
% Express g-vectors as tensors in the T-frame
g1 = diag(Sys1.g(1,:));
g2 = diag(Sys1.g(2,:));
% Transform g-tensors from T to M-frame
g1M = R_T2M_1 * g1 * R_T2M_1.';
g2M = R_T2M_2 * g2 * R_T2M_2.';
% Dipolar exchange with Sys.ee and WITH Easyspin frames in the molecular frame
D12 = transpose(g1M)*g2M - 3 * (transpose(g1M)*R12) * (transpose(R12)*g2M);
dip = -12993 * r12^-3 * D12; % MHz in the +JSiSj formalism
jiso = J*eye(3)*cm;
Sys1.ee = dip + jiso;
%% Define FS experimental conditions
% Define CW experiment and plot a CW spectrum
Exp.mwFreq=9.7; Exp.Range=[340 355]; Exp.nPoints=50; Exp.Harmonic = 1;
Opt.Threshold=0; Opt.Transitions = 'all';
[B,spc_new_eeframes] = pepper(Sys1,Exp,Opt);
figure(1)
plot(B,spc_new_eeframes,'Color','k','DisplayName',"eeD g-Molecular ee frame")
axis tight
xlim([330 360])
% Calculate pulse at each field
for jj = 1:length(B)
    % For the spin expectation values of nth state define ... (nth = 1 for the ground state)
    nth = 1;
    Heig = B(jj);
% Calculate probability amplitudes
H = sham(Sys1,[0,0,Heig]); % Generate the Hamiltonian matrix of the system
[Vt,Ener]=eig(H); % Generate the right-hand vectors (Vt = |>) and the energy eigenvalues (Ener) of the Hamiltonian (in MHz)
[S1x,S1y,S1z,S2x,S2y,S2z] = sop(Sys1,'x1','y1','z1','x2','y2','z2');
[S1p,S1m,S2p,S2m] = sop(Sys1,'+1','-1','+2','-2');
[S1pS2m,S1mS2p,S1zS2z] = sop(Sys1,'+1-2','-1+2','z1z2');
S1 = S1x + S1y + S1z;
S2 = S2x + S2y + S2z;
S1S2 = 1/2 * (S1pS2m + S1mS2p) + S1zS2z; % S1*S2
S_2 = S1*S1 + S2*S2 + 2*S1S2; %ST^2
Sx = S1x+S2x;
Sy = S1y+S2y;
Sz = S1z+S2z;
flipAngle = pi/2;
signal = zeros(n,length(tp));
for p = 1:length(tp)
  for k = 1:length(offset)
    Ham0 = offset(k)*Sz;
    Pulse = expm(-1i*(flipAngle*Sx+2*pi*tp(p)*Ham0));
    TauEvol = expm(-2i*pi*tau*Ham0);
    U = Pulse^2*TauEvol*Pulse;
    signal(:,p) = signal(:,p) + ...
      weights(k)*real(evolve(U*Sz*U',Sy,Ham0,n,dt));
% Result: The longer the pulses, the broader the
% echo.
figure(2)
plot((0:n-1)*dt,signal);
hold on
title('The shape of the primary echo depending on the pulse length');
xlabel('time after the pi pulse [μs]');
ylabel('echo signal');
Posted: Mon Feb 06, 2023 4:14 am
by thanasis
I have also been trying saffron along these lines.
There is an error I get for the above system:
Error using saffron>rotatesystem (line 2342)
Reference to non-existent field 'eeFrame'.
Error in saffron (line 1993)
  parfor iOrientation = 1 : nOrientations
Error in twopecho_dimer_saffron (line 119)
    [x,y] = saffron(Sys1,Exp,Opt);
The respective script is:
% advanced usage.
%% Define system
gx = 2.002;
gy = 2.002;
gz = 2.002;
gx1 = 2.002;
gy1 = 2.002;
gz1 = 2.002;
gx2 = 2.006;
gy2 = 2.006;
gz2 = 2.006;
% Spin system
Sys1.S= [1/2 1/2];
Sys1.lwpp=[1 0];
    % A-frames
jiso = J*eye(3)*cm;
% Plot a CW spectrum
figure(1)
axis tight
xlim([330 360])
% Calculate pulse intensity at each field
Sys1.T1 = 250; % In μs
Sys1.T2 = 8; % In μs
Exp.Sequence = '2pESEEM';
Exp.dt = 0.00;
Exp.nPoints = 1;
Exp.tau = tau;
Opt.GridSize = 31;
for jj = 1:length(B) Exp.Field = B(jj); [x,y] = saffron(Sys1,Exp,Opt); FSED(jj) = y; end
Posted: Mon Feb 06, 2023 7:20 am
by thanasis
The error must be associated with the ee-interaction term.
When trying with a 1-spin system, the error disappeared, but another one popped up:
Attempt to grow array along ambiguous dimension.
Error in saffron (line 1256)
        SyLab(rmvTransition~=0) = 0;
Error in saffron (line 237)
        [x,y_,out] = saffron(Sys_,Exp,Opt);
Error in twopecho_monomer_saffron (line 75)
Posted: Tue Feb 14, 2023 5:10 pm
This is indeed a bug - thanks for reporting. It is now fixed, and the fix will appear in the next release (6.0.0-dev.52).
