I have found that standard xml readed by eprload
output file contains relatively roughly rounded values (4 signs after decimal points). Initial xml file contains more precision values in the field like <Measurement Name="Cudppeth_05_tmp_-43C" Device="MS-5000 [11-0273]" FWV="FW master: 10.0.6
FW slavemw: 10.1.2
FW slavebf: 10.0.4
FW slaveiq: 10.0.0" SWV="ESRStudio 1.74.4" Timestamp="2021-04-29T12:19:40.5555133+03:00" MwFreq="9.47201614223679" GonAngle="0" Temperature="-43.2197937011719" Concentration="0" ConcentrationUnit="" XDatasource="BField" XUnit="mT" YDatasource="MW_Absorption" YUnit="" Mode="Vis" Mass="0" SampleDiameter="0" SampleHeight="0" SpinConcentration="0" SpinCount="0" SpinsPerMole="0" TotalElectronSpin="0" MarkerAmplitude="NaN" MarkerPosition="NaN" NonMarkerAmplitude="1244.48715902379" AmbientTemperature1="0" AmbientTemperature2="0" AmbientHumidity="0" QFactor="-1" Phase="0" FilterPrm0="0.03" FilterType="DIG">
Can I hope the function eprload
will extract more precision data or I have to write my own parcer for MS5000 xml files?
Inconvenient work of eprload with MS5000 xml files
Re: Inconvenient work of eprload with MS5000 xml files
Please post the xml file you are trying to load. Which quantities are you referring to, magnetic-field values or microwave frequency?
There is the example of the xml file.
I've additionally found that the private function xml2struct.p
give expected results.
- Cudppeth_05_tmp_-3C.rar
- example of the xml file
- (1.09 MiB) Downloaded 806 times
If you a referring to the field and spectral values in that file, then I don't see anything wrong:
>> [B,spc,par] = eprload('Cudppeth_05_tmp_-3C.xml');
>> format long % turn on full-length display of numbers
>> B(1:5)
ans =
1.0e+02 *
3.320003099942436
3.320011239453875
3.320019378965315
3.320027518476755
3.320035657988194
>> spc(1:5)
ans =
-0.991538610927996
-1.232134389237260
-1.581659094930004
-2.026221140079262
-2.554633473447652
>> [x,y,p]=eprload('Cudppeth_05_tmp_-3C.xml');
gives an answer
disp(p.MwFreq)9.4719
>> par=xml2struct('Cudppeth_05_tmp_-3C.xml');
gives correct answer
disp(par.ESRXmlFile.Data.Measurement.Attributes.MwFreq)9.47186304271149
Ah, I see the issue now. par.MwFreq
is a number, so you need the proper setting of format
to get all the digits displayed. In contrast, par.ESRXmlFile.Data.Measurement.Attributes.MwFreq
is a string.
Here is an example of how the format
setting affect display of numbers:
>> a = sqrt(2);
>> format short
>> a
a =
1.4142
>> format long
>> a
a =
1.414213562373095
Thanks for explanation. It's indeed true.
