Using esfit for magnetometry data
dungeonfunk
Post by dungeonfunk »
Hi everyone,
I am trying to fit magnetometry data (magnetic susceptibility) using the curry function, using J as my fitting parameters. The problem I am running into is that for an 8 spin system, each J is treated as a different parameter. I would like to add the constraint that all J's are equal or scaled by a certain value. Here is a three spin example of the method I am using after importing a data set.
%importing some data
exchi = datay;
expT = datax;
FitSys.S = [S S S];
FitSys.g = [g;g;g];
FitSys.J = [J1 J1 J1]/1.44*30000;
FitSys.D = [Dpv;Dpv;Dpv];
Exp.CrystalOrientation = [0 0 0];
Exp.Temperature = ;
Exp.Field = 100;
%vary parameters
Vary.J = [90000 90000 90000];
FitOpt.Scaling = 'none';
ChiOpt.Output = 'ChiCGS OneColoumn';
bestchi = esfit('curry',expchi(:),FitSys,Vary,Exp,ChiOpt,FitOpt);
chioptdata.Output = 'ChiCGS';
chisim = curry(bestchi,Exp,chioptdata);
I have also attempted to use the 'user defined functions' but am not exactly sure how to include this type of constraint. Any help on this matter would be appreciated.
Thanks.
Re: Using esfit for magnetometry data
You may start by looking at posts:
viewtopic.php?f=3&t=260
viewtopic.php?f=3&t=261
They refer to the previous specification of Easyspin for magnetic susceptibility data, but the use of custom functions is roughly the same.
