Breit-Rabi solver as separate function
Is it possible to extract Breit-Rabi solver from garlic and write separate functions like resfields/resfreqs? It seems not to be extremely hard.
Re: Breit-Rabi solver as separate function
That's in principle possible, but it is not sure how much that functionality is needed.
Here is a short script for the Breit-Rabi fixed-point solver:
giso = 2;
Nuc = '1H';
aiso = 1000; % MHz
mwFreq = 9.6; % MHz
Opt.MaxIterations = 15;
Opt.Accuracy = 1e-12;
gn = nucgval(Nuc);
I = nucspin(Nuc);
mI = -I:I;
B = 0;
mwFreq = mwFreq*1e9; % MHz -> Hz
aiso = aiso*1e6*planck; % MHz -> J
gammae = giso*bmagn;
gamman = 0; % to obtain start field, neglect NZI
relChangeB = inf;
for iter = 1:Opt.MaxIterations
  nu = mwFreq + gamman/planck*B;
  q = 1 - (aiso./(2*planck*nu)).^2;
  Bnew = aiso./(gammae+gamman)./q.* ...
    (-mI+sign(aiso)*sqrt(mI.^2+q.*((planck*nu/aiso).^2 - (I+1/2)^2)));
  if ~isreal(Bnew)
    error('Hyperfine coupling too large compared to microwave frequency.');
  if (B~=0), relChangeB = 1 - Bnew./B; end
  B = Bnew;
  gamman = gn*nmagn; % re-include NZI
  if abs(relChangeB)<Opt.Accuracy, break; end
B
Thanks a lot. It isn't completely clear how to treat several nuclei however. I suggest that resonances for first nucleus should be converted into frequency and each one should be used as mwFreq for second nucleus. Is it right way?
There is no exact solution for this except diagonalizing the full Hamiltonian. garlic neglects the nuclear-nuclear cross terms. With that assumption, the shifts from different nuclei are additive.
Thanks. I suggest that proposed solution should be working at least for systems with only one large HFC constant (like metalloradicals). I would like to adapt exchange function for systems like copper(II) or rhodium(II) complexes with relatively large hyperfine splitting (over 100G). Default first-order solver should be absolutely inappropriate, although it may be used for nuclei with I=1/2 with some tricks. Nuclei with I>1/2 (like Cu or As) cannot be treated absolutely. The function resfields_perturb in second-order treatment gives better results but I have certain doubts about its applicability for such large HFC constants. Unfortunately, resfields returns resonances in unpredictable order (viewtopic.php?f=4&t=411) although it should be the best choice of course.
And one more question, how garlic treats equivalent nuclei? I think it uses equivcouple representation with followed accumulation of the spectra, is it so?
Correct, garlic uses equivcouple to deal with equivalent spins.
