Hi all,
I want to simulate epr spectrum by using orca2easyspin. Then first I calculated epr tensors by orca (.prop file), and using orca2easyspin generate further data. I got such information:
Sys =
S: 1
xyz: [29X3 double]
Charge: 0
g: [2.0022 2.0028 2.0037]
gFrame: [0.1510 1.1134 -1.8332]
Nucs: 'N,C,H,C,H,N,C,C,C,C,C,H,C,N,H,H,H,C,C,C,H,C,H,C,H,C,H,C,N'
A: [29X3 double]
AFrame: [29X3 double]
Q: [29X3 double]
QFrame: [29X3 double]
to accelerate such simulation, i choose perturb method in pepper
Sys.lwpp =1; %mT
Exp.mwFreq =9.8; %GHz
Exp.Range = [315 368]; %mT
Opt.Method= 'perturb2';
[x,y]= pepper(Sys,Exp,Opt);
while three days passed, this work still in process. So i want to know are there any method to accelerate pepper process? My computer is linux system and 32 core, 128GB memory.
Thanks,
Sa
How to accelerate pepper process
Re: How to accelerate pepper process
I suggest that spin system with 29 nuclei is extremely large. Firstly, all of C nuclei may be droped. Secondly, other nuclei with small HFC constants may be excluded too. The functions
nucspinrmv
or nucspinkeep
may help in this. At third, I don't shure that perturbation method is appropriate choise for systems with S=1. I suggest that hybrid method should be used (matrix treatment for electron spins and perturbation for nuclear ones).Re: How to accelerate pepper process
thank you.katarkon wrote:I suggest that spin system with 29 nuclei is extremely large. Firstly, all of C nuclei may be droped. Secondly, other nuclei with small HFC constants may be excluded too. The functionsnucspinrmv
ornucspinkeep
Yes, most likely, the computer can't even store the Hamiltonian in Matrix Form, as the dimension is (2^30)x(2^30) (if all spins are 1/2).I suggest that spin system with 29 nuclei is extremely large.
orca2easyspin[c] takes a hyperfine cutoff as second parameter. E.g. if you set it to 0.5, all nuclei with hyperfine couplings less than 0.5 MHz will be removed from the spin system.
