Page 2 of 2
Re: Error "Attempt to reference field of non-structure array
Posted: Fri Jul 14, 2017 12:33 am
by thanasis
What I mean:
After making a cli run with esfit to extract the ascii file with the calculated composite spectrum (mydatafile_fitcurve.txt), while also having extracted the ascii subspectra and their sum (Cu7_total.txt) from the fitting function as I previously updated it, I do the following:
load Cu7_total.txt; % Load the sum of the subspectra as derived from the fitting function (Cu_monomer + Cu_trimer)
load mydatafile_fitcurve.txt; % Load the calculated (scaled) composite spectrum as derived from esfit
ratio=mydatafile_fitcurve(:,2)./Cu7_total; % Divide the two curves point per point
plot(B,ratio)
If scaling was the only difference, shouldn't we be getting a straight horizontal line? Or would that be the case assuming a specific scaling method?
Posted: Fri Jul 14, 2017 7:47 am
Please post a complete script that defines all parameters for the esfit call.
Posted: Fri Jul 14, 2017 8:08 am
by thanasis
Script:
clear all;
close all;
fname = 'skg10607.spc';
[B, spc, params] = eprload(fname);
%The spin system
Sys1.S=1/2;
Sys1.g=[2.064 2.244];
Sys1.lwpp = [0 6];
Sys1.Nucs = 'Cu';
Sys1.A = [0 515];
Sys2.S = 1/2;
Sys2.g = [1.74 2.18];
Sys2.gStrain = [0.29 0];
Sys2.lwpp = [0 13];
Sys2.weight = 0.8;
Exp.Temperature = 4.1; Exp.mwFreq=params.MF; Exp.CenterSweep=[((params.HCF-25.76)/10) params.HSW/10]; Exp.nPoints=params.RES;
Vary1.g = [0.0 0.0];
Vary1.lwpp = [0 2];
Vary1.A = [0 0];
Vary2.g = [0.0 0.01];
Vary2.gStrain = [0 0];
Vary2.lwpp = [0 2];
Vary2.weight = 0.;
% Call the fitting function
FitOpt.Method = 'simplex diff';
FitOpt.Scaling = 'lsq1';
[BestSys,BestSpc] = esfit('decompose_v2',spc,{Sys1,Sys2},{Vary1,Vary2},Exp,[],FitOpt);
datafname = [fname,'_fitcurve.txt'];
calcdata = [B(:) BestSpc(:)]; % Arrange calculated data as an ascii file
save(datafname,'calcdata','-ascii'); % Save the calculated curve as an ascii file
decompose_v2.m:
function [x,y] = decompose_v2(Sys,Exp,Opt)
[x,y_monomer] = pepper(Sys{1},Exp,Opt);
[x,y_trimer] = pepper(Sys{2},Exp,Opt);
calc_monomer = y_monomer'; save('Cu7_monomer.txt','calc_monomer','-ascii');
calc_trimer = y_trimer'; save('Cu7_trimer.txt','calc_trimer','-ascii');
figure(234);
% subplot(2,1,1)
plot(x,y_monomer)
drawnow
hold on
% subplot(2,1,2)
plot(x,y_trimer)
drawnow
y = y_monomer + y_trimer;
calc_total = y'; save('Cu7_total.txt','calc_total','-ascii');
plot(x,y)
hold off
Then in matlab's cli:
load skg10607_spc_fitcurve.txt; % Load the calculated (scaled) composite spectrum as derived from esfit
ratio=skg10607_spc_fitcurve(:,2)./Cu7_total; % Divide the two curves point per point
plot(B,ratio)
The data file is the uploaded one.
Posted: Fri Jul 14, 2017 8:16 am
You specified 'lsq1'
scaling, which includes a linear baseline in the fit.
Posted: Fri Jul 14, 2017 8:35 am
by thanasis
That's right!
I just tested that maxabs
gives excellent agreement; minmax
and lsq0
not so.
Now it seems obvious!
Thanks Stefan!
