Exporting Least Square fitting data
sg_epr
Post by sg_epr »
I want to export the simulated data after L-S fitting (esfit) in *.txt format. When I tried
 S2 = [B(:) spc(:)];
save(XYZ.txt','S2','-ascii');
the generated text file had only the experimental data, not the simulated one. Would appreciate any suggestion. Thanks
Abbey Philip
Re: Exporting Least Square fitting data
Post by Abbey Philip »
I'm not an EPR expert, however the complete code might be somewhat helpful for finding any errors.
Also, there seem to be a apostrophe missing before the name of the text file, i.e. 'XYX.txt'.
