Exp.Mode
amateur
Exp.Mode
Post by amateur »
Exp.Mode = angle;
where angle is a single number representing the k_tilt angle in radian produces an error message:
Error using p_excitationgeometry (line 80)
Exp.Mode must contain 1 or 2 angles (k tilt angle, polarization angle
Error in D:\easyspin-5.0.11\easyspin\resfreqs_matrix.p>resfreqs_matrix (line
155)
Error in D:\easyspin-5.0.11\easyspin\pepper.p>pepper (line 639)
Error in D:\easyspin-5.0.11\easyspin\pepper.p>pepper (line 127)
It works fine with an array like:
Exp.Mode = [angle 0];
but single angle should be allowed.
Best wishes,
Joscha
Re: Exp.Mode
For single input, it's not clear what the obvious choice for the default value for the second parameter (polarization angle) is. Therefore, EasySpin currently requires both the beam tilt angle and the polarization angle.
