Problem with importing orca data
sc262
Post by sc262 »
Hello, when I am trying to import the results of an orca calculation using the files attached herewith. I end up with two different errors each time.
Sys = orca2easyspin('test1.prop');
Error using reshape
To RESHAPE the number of elements must not change.
Error in orca2easyspin (line 93)
Error in myfit (line 22)
Sys = orca2easyspin('test2.prop');
Undefined function or variable "QFrame".
Error in orca2easyspin (line 170)
Looking forward to hear from you.
test2.prop
(2.43 KiB) Downloaded 453 times
test1.prop
(1.99 KiB) Downloaded 472 times
Re: Problem with importing orca data
Hi, this looks like a bug. Can you please post the ORCA input files, and also tell us which version of ORCA you are using?
test2.prop actually works fine with the current EasySpin version 5.0.5.
For test1.prop, please post the corresponding ORCA input and output files.
sc262
Post by sc262 »
Hi Stefan, It is working fine with the new version of Easyspin. Thanks
Great!
