I'm trying to simulate a CW biradical spectrum, and I'd like to be able to have a constraint so that the g-values of the two radicals are kept the same (although I still want to have EasySpin optimize the g-values). How would you do this?
Thanks,
Alex
(MatlabR2014b, EasySpin4.5.5, Windows7Pro)
Applying additional constraints in esfit
- User
Re: Applying additional constraints in esfit
Alex,
that's quite simple: Create your own simulation function, say
In the body of the function, do whatever you need to do to constrain the values, then call the ES simulation function, and return the simulated spectrum.
All that remains is to call
mysim.m
that defines a function with the same syntax as all the ES simulation functions:
function [x,y] = mysim(Sys,Exp,Opt)
% Here comes your code
esfit
with your custom simulation function:
esfit('mysim',data,Sys,Sys0,Vary,Opt)
Actually I have the same problem with hyperfine constants of Copper ions in a dinuclear complex. I want to simulate the triplet spectrum of this complex and
I want to have identical A values for the two copper ions during the fitting procedure.
Unfortunately I really do not understand your answer. I must confess that I started to use easyspin last week and I never use MatLab before.
Do you mind to give more details about the solution you proposed to solve the problem
many thanks
Yves
Sys. Nucs = ‘Cu, Cu';
Sys. A = [30 245 ; 30 245] ;
Sys. S = 1 ;
Sys. g = [2.0238 2.0815 2.2956] ;
Sys. HStrain = [217 344 250] ;
Exp. Range = [250 450] ;
Exp. mwFreq = 9.47508 ;
SimOpt. nKnots = 25 ;
SimOpt. Method = 'perturb’;
Vary. A = [0 100 ; 0 100] ;
Vary. HStrain = [0 0 50] ;
FitOpt. Method = 'simplex fcn';
FitOpt. Scaling = 'maxabs’; % scaling so that the maximum absolute values coincide
esfit(‘pepper’,spc ,Sys ,Var y,Exp ,Sim Opt,Fit Opt);
many thanks
Yves
Sys. S = 1 ;
Here is how you should write the function for your case:
The call
function [x,y] = simCuCu(Sys,Exp,SimOpt)
Sys.A = [Sys.ACuCu; Sys.ACuCu];
[x,y] = pepper(Sys,Exp,SimOpt);
esfit
in the following way:
Sys.Nucs = 'Cu,Cu';
Sys.ACuCu = [30 245];
Sys.S = 1;
Sys.g = [2.0238 2.0815 2.2956];
Sys.HStrain = [217 344 250];
Exp.Range = [250 450];
Exp.mwFreq = 9.47508;
simOpt.nKnots = 35;
simOpt.Method = 'perturb';
Vary.ACuCu = [0 100];
Vary.HStrain = [0 0 50];
fitOpt.Method = 'simplex';
fitOpt.Scaling = 'maxabs';
esfit('simCuCu',ydata,Sys,Vary,Exp,simOpt,fitOpt)
Dear Colleague
Thank you very much for your rapid answer and your explanations.
I am very busy today and I will try your suggestions probably next week.
By the way, easy spin is just great and a lot better than the other software I used before. I am very grateful to you for this major contribution to the EPR community
- User
I too would like to thank you for your help. I still haven't gotten around to actually implementing it, but it makes sense.
