The optimization method does not support tcorr exchange systems
YanQing
Post by YanQing »
code:
clear; clc; clf;
Exp.mwFreq = 9.8;
Exp.nPoints = 1e5;
Exp.CenterSweep = [350 3];
Sys2.Nucs = 'N,H,H';
Sys2.n = [2 4 4];
Sys2.A = mt2mhz([0.514 -0.193 -0.161]);
Sys2.lwpp = 0.01;
Sys2.logtcorr = -9;
ExchangeFreq = 20.*linspace(0.5,2,10);
for i = 1:numel(ExchangeFreq)
Sys2.Exchange = ExchangeFreq(i);
[b,spc(i,:)] = chili(Sys2,Exp);
stackplot(b,spc);
xlabel('magnetic field (mT)');
h2 = findobj(gca,'Type','line');
set(h2,'linewidth',1.5);
grid on;
errors:
Error using chili
Opt.LiouvMethod='general' does not support spin exchange (Sys.Exchange).
Error in chili
Error in Untitled2 (line 18)
How should I fix the code?
Re: The optimization method does not support tcorr exchange systems
There's nothing you can do to fix it - Sys.Exchange is just not implemented in chili for spin systems with more than two nuclei.
YanQing
Post by YanQing »
Thank you for your answer and look forward to adding this feature in the later update of easyspin!
good luck!
