I have tried to use eprload function in easyspin for Mannettech file (.spe) upload but it gives me an error (the size of file is wrong).
Could you update eprload function for these .spe files?
I attached an example, of file.
Thank you.
Magnettech .spe fail conversion
- air_P 1_0.Spe
- (2.06 KiB) Downloaded 287 times
Re: Magnettech .spe fail conversion
As far as we know (based on manufacturer information), Magnettech spe files are always 8256 bytes long, containing 8192 bytes (4096 points) of spectral data. Your file has only 1024 data points. Which Magnettech spectrometer and software version were used to acquire these data?
Version of software ver.1.0.0.1542, Power supply MPS3, control unit CU400. Spectrum contains 1024 points.
Is this an MS400 or MS5000 spectrometer? What year (approx.) was this spectrometer built? Can you change the number of points in the software? What is the name of the software?
Manual says MT 500-L. DFoes it help?
Sorry did not read completely. Last year production, can change point number, software name ModularControlV1.0.0.1542
That's useful information, thanks. What are the possible settings for the number of points?
512-4096
Thank you. We should be able to fix this quickly. Stay tuned.
Fixed in 5.2.9
