Posts: 188 Joined: Mon Jan 12, 2015 4:01 am
Post
by katarkon » Fri Sep 08, 2017 4:08 am
The function esfit() throws an error in interactive mode.
Error using set
Value must be numeric
Error in C:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Posts: 1085 Joined: Mon Jul 21, 2014 10:11 pm
Post
by Stefan Stoll » Fri Sep 08, 2017 8:13 am
(1) Which Matlab version are you using?
(2) Please post your input to esfit
Post
by katarkon » Sat Sep 09, 2017 1:08 pm
Matlab version is R2012b. Error throws by any script from examples. For instance, basicfit.m output:
Error using set
Error in E:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Error in basicfit (line 37)
esfit('pepper',spc,Sys0,Vary,Exp,SimOpt,FitOpt);
Post
by Stefan Stoll » Sun Sep 10, 2017 10:01 pm
Fixed in 5.2.1. Thanks for reporting!
Post
by katarkon » Tue Sep 12, 2017 4:34 am
Best spectrum (green) is drawn spontaneously now. It seems to be appeared only when the best parameter set changes. So, if better set will not be found during the fitting the spectrum never be drawn. Should it be so?
Post
by Stefan Stoll » Tue Sep 12, 2017 5:17 pm
Behavior is now improved in 5.2.2
Post
by katarkon » Tue Sep 12, 2017 10:55 pm
Thanks. It works habitually now.
