Bug in esfit function (EasySpin 5.2.0)
Postby katarkon » Fri Sep 08, 2017 4:08 am
The function esfit() throws an error in interactive mode.
Error using set
Value must be numeric
Error in C:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Resident User
Re: Bug in esfit function (EasySpin 5.2.0)
Postby Stefan Stoll » Fri Sep 08, 2017 8:13 am
(1) Which Matlab version are you using?
(2) Please post your input to esfit.
Postby katarkon » Sat Sep 09, 2017 1:08 pm
Matlab version is R2012b. Error throws by any script from examples. For instance, basicfit.m output:
Error using set
Error in E:\easyspin-5.2.0\easyspin\esfit.p>esfit (line 348)
Error in basicfit (line 37)
esfit('pepper',spc,Sys0,Vary,Exp,SimOpt,FitOpt);
Resident User
Postby Stefan Stoll » Sun Sep 10, 2017 10:01 pm
Fixed in 5.2.1. Thanks for reporting!
Postby katarkon » Tue Sep 12, 2017 4:34 am
Best spectrum (green) is drawn spontaneously now. It seems to be appeared only when the best parameter set changes. So, if better set will not be found during the fitting the spectrum never be drawn. Should it be so?
Resident User
Postby Stefan Stoll » Tue Sep 12, 2017 5:17 pm
Behavior is now improved in 5.2.2
Postby katarkon » Tue Sep 12, 2017 10:55 pm
Thanks. It works habitually now.
Resident User
Return to Bugs
Who is online
Users browsing this forum: No registered users and 1 guest
