I have been using the Sys.ee function to simulate spin-spin interaction in my system. For example, I wrote:
Sys.S = [1 1];
Sys.g = [2.0004 ; 2.0004];
Sys.lwpp = 0.5;
Sys.ee = [1 1 2]*270
It fits well the experimental data but I am not sure about the meaning of [1 1 2]*270. Can you help me ? Does it mean that the interaction is worth 2*270=540 MHz ?
Thank you very much for your help,
Cheers,
Geraldine
Spin-spin interaction
Re: Spin-spin interaction
Sys.ee includes all forms of electron-electron interactions, no matter what the physical origin is.
Check out the corresponding ES documentation.
Did you mean [-1 -1 2]*270? If yes, this is just the through-space dipolar coupling between two electron spins,
aligned along the z axis.
No, I really meant [1 1 2]*270 ...
What about the value of the coupling ? Is it 540 MHz ?
Thanks,
Thanks,
- EasySpin Guru
Geraldine wrote:No, I really meant [1 1 2]*270 ...
Thanks,
Jiso = sum([1 1 2]*270)/3 = 360
Jdip = [1 1 2]*270 - Jiso = [ -90 -90 180] = 90*[-1 -1 2]
Great !
Many thanks !!!!!
Many thanks !!!!!
