Parallelization
Parallelization
Postby jiten.phy » Sat Jan 20, 2018 9:20 am
Hello everyone,
I am new to EasySpin and below is my first ever code in EasySpin. The system is a CuPc molecule with Cu(2+) having a unpaired electron in a hyperfine interaction with Copper nucleus and four neighboring nitrogen nucleus. The problem is of too much simulation time. Is this code can be parallelized; if yes, then how? One more doubt, can I get echo amplitude versus magnetic field with EasySpin?
Thanking You.
Jitendra
Exp.Sequence = '2pESEEM';
Exp.Field = 330;
Exp.dt = 0.010;
Exp.tau = 0.1;
Exp.T = 0.06;
Sys.g =[2.039 2.039 2.1577];
Sys.Nucs = '63Cu,14N,14N,14N,14N';
Sys.A = [-83 -83 -648; 57 45 45; 57 45 45; 57 45 45; 57 45 45];
saffron(Sys,Exp);
jiten.phy
Re: Parallelization
Postby Stefan Stoll » Thu Jan 25, 2018 11:07 pm
This is a large spin system, so it is not surprising that it takes some time. Did you look into the option Opt.ProductRule?
Return to General forum
Who is online
Users browsing this forum: No registered users and 2 guests
cron
